8kw Deye inverter settings to use with new prepaid meter
Hi, can anyone help me as to how I can get the best setup to use for a newly installed Tshwane prepaid meter. I have a 8kw Deye inverter and a 200ah Deye lithium battery. I previously had the old disc type meter. I am planning to install another 200ah at a later stage to try to use less grid power.
Cannot give you the best settings. This works for me with the new prepaid meters in Tshwane. Ignore the 3000W selling 1st as yours can be 8000W.
Your timer settings will be as per your load profile. I have grid charge on from 17h00 up to 21h00 when gadgets in the kitchen are used to prevent discharge of battery.
Also ignore the grid peak shaving of 3500W.
