May 5, 20251 yr Hi,Can anyone assist with where to find and download the Solar Wize 3KVA interface software ?I also have a problem with this inverter in that it shows PVs connected on the display as well the PV input voltage but will not switch to the PVs for load and/or battery charging irrespective of which priority I select; defaults to Utility as input for loads and battery charging. When I connect just the PVs and the batteries (leave Utility wiring un-connected), it picks up the Pvs. Anyone have any ideas as to how I could resolve please.Thank you very much
