June 17, 20251 yr I have 3 svolt batteries in parallel. Two work correctly but the third stays at full charge. They are all connected to the same busbar. It tops up at times drawing power from the other two batteries at high amps Edited June 17, 20251 yr by mark penkin More info
June 17, 20251 yr @mark penkin ,Tell us a bit more...like 1) Link cable to Inverter (what type) is present and working/setup correctly?2) Dip switch settings for master and slaves3) Master/Slave battery link cable installed4) Which type of S Volt batteries you have.PS, even if you have setup dip switches correctly, did you restart each battery (to take the new settings)?
