Anern Evo 6200 wifi module
Hello, I own a hybrid inverter, the Anern Evo 6200. I have a WiFi module with an RJ45 connector that operates using the RS485 protocol. I would like to know if it is possible to modify it so that it works with RS232, which is the protocol used by my inverter for WiFi connectivity.
Attached are some images of the module I have.
  • 7 months later...
I have the same inverter and I'm struggling to get it to work with wifi plug pro 05
I bought some cables to debug this issue, I found a project on github that uses rs232 to monitor the data from the inverter (Anern SCI-EVO-6200)
https://github.com/jonaubf/anern-inverter-monitoring
But even when I connected to my inverter, the project didn't work!
Now I tried to connect to the inverter at baud rate 2400 and I only got gibberish like this
bfiˇˇC◊¶hÎ÷.fi¯B¡¸Ê.˝.D.ˇ◊ˇ∆¶÷◊.ÃpÎ.fi‡.¯ˇfi˝˙F..‹Œ.ˇ◊B¶◊ˇ◊fi˝fi‹¶¬ò◊Œ¡∆å˝&fi˝˝.˝.˝ˇfi¯fiˇ¶˙∞fi¯ê÷N◊◊†».¯.p¯@Ò»ÛÄÏ.....”‰ˇÿ.¸|§à˚≤ˇ˙¯⁄[.„ˆ¢.¨
every second I get one new byte
but when I connected to baud rate 9600, I started getting readable ascii strings like this, and it didn't change.
~25004642E002FFFD06
~25004642E002FFFD06
~25004642E002FFFD06
now I think this is for BMS Communication based on this thread here https://powerforum.co.za/topic/10575-solax-inverter-comms-with-pylontech-us3000c-bms/#comment-206810
I tried contacting the wifi plug pro 05 company and the anern company and both ghosted me after telling me to restart, replug the dongle and what not.
I'm really hoping to find a solution for this!
