Completed Upgrade: 20kW PV Hybrid System with AC & DC Coupling
I recently finished a major upgrade to my solar setup in mostly sunny Abuja Nigeria. Previously I was running a 10 kW PV array with:
  • 2 × Victron Smart MPPT 250/100
  • 10 kVA Multiplus II
  • 28 kWh LiFePO₄ storage
I’ve now expanded to a 20 kW hybrid setup:
PV Generation
DC Coupled
  • 5.4 kW Canadian Solar → Victron Smart MPPT 150/100
  • 5.2 kW Jinko → Victron Smart MPPT 250/100
  • 3.5 kW Jinko → Victron Multi RS (MPPT1)
  • 4 kW Jinko → Victron Multi RS (MPPT2)
AC Coupled
  • 2.5 kW Longi → Deye SUN-M220/225G4 Micro Inverter (AC coupled to heavy load inverter output)
Inverters & Loads
  • Victron Multiplus II 10 kVA → Dedicated to heavy appliances (3 × 1.5 HP AC, 2 × 2 HP AC, 3.7 kW induction cooker, 3 kW oven, multiple water heaters).
    • AC-coupled to the Deye Micro Inverter, which steps in during the day to share load.
  • Victron Multi RS 6000 VA → Handles lighter loads (lighting, TV, sockets, etc).
  • Both run on separate house circuits (wired this way from the start).
Battery Storage
  • 14.7 kWh × 4 (≈ 56 kWh total) LiFePO₄ banks
  • JK Inverter BMS (4 units, parallel linked via CAN)
  • Integrated with GX device via CAN
GX Device
  • Raspberry Pi Compute Module 4 (eMMC) + dual CAN hat + cooling fan in DIN-rail case
  • Running Venus OS Large
  • Chose this route to leverage Node-RED automation & extra compute power (also had spare Pis).
  • DIY GX solution was more cost-effective and very flexible.
DIY & Cost-Saving Hacks
  • Built my own “poor man’s Lynx distributor” using a SmartShunt + busbars — works perfectly.
AC Coupling Behavior
The Deye Micro Inverter impressed me: it reacts quickly to frequency shifts from the Multiplus.
  • At absorption (55.2 V), the system smoothly adjusts as the Deye ramps down.
  • The Multiplus manages frequency shifts to keep balance without issue.
I’ll post a more detailed review of the Deye soon, since there’s very little info here about its performance in AC-coupled mode.
Automation & Monitoring
  • Heavy use of Node-RED for smart automation.
  • Example: weather forecast automation (via Solcast) predicts next-day solar yield and adjusts grid-input allowance automatically.
  • Monitoring migrated to Grafana (self-hosted) → richer metrics than VRM and full data ownership.
👉 Live Dashboard:
https://helio.openculture.org.ng/public-dashboards/867d6afd562543508eaf080533e7b652
25 minutes ago, mzezman said:
How much runtime are you able to get on those batteries alone? I am assuming you are completely off-grid?
Yes the system is completely off grid (although there is a grid option, it is turned off) The battery can give 2 days of electricity if we don't change anything on how we use power. and close to 5 days if we switch to essential appliances.
Star Wars GIF
