November 2, 2025Nov 2 Hello all. As title says, I have a strange situation with a JK bms. The setup is this: a jk bms PB version v15, an Easun SMG II 11 kw. Li2 protocol set up in inverter and Pylontech 9600 set up in bms. My RCV is set up to 3.45 v, corresponding with 55.2 v pack(16S). However, the inverter is charging the battery until 56.8v. I don’t understand why it charges until this voltage, as long as the target bulk voltage is 55.2v, which is also seen in inverter’s screen. Can someone help me with this? I’m attaching also my bms settings . Thanks.
