April 9, 20197 yr Hi all First post here. 5 Kw inverter and 8x105Ah deep cycle batteries. I have installed 2 of these setups at my office and holiday house by myself, but have run into an issue at my main house. Three phase power on the main board and a sub DB at the other end of the house. I want to eliminate the geyser breakers on the inverter circuit, problem is, they are on the sub DB (other breakers on the sub DB should be on the inverter circuit) and the inverter will be wired into the main board. Any idea of how this can be done? Happy to provide clarity or pictures if needed. Thanks. Or if anyone can recommend a competent installer in the Sandton area.
