Axpert MKS II firmware
Hi all, first post here, thanks for adding me. I have 9 x Axpert MKS II 5kW clones in parallel, 7 of them (Easun Isolar SM II) running on 71.87 and the other 2 (MKS II 5kW-B) running on 50.01 and 50.02. I have tried to update 50.XX to the 71.XX but getting "can't open COM port " error. Is there an intermediate F/W or Inverters with 50.XX running their own version of F/W which can't be upgraded? Attached are the 3 different inverter models on the same system, any thoughts? Thank you
Edit: I have noticed 50.01 and 50.02 is only listed for Axpert King II inverters, but mine are MKS II... Attached pics of the displays as well.
Edited by andrey123456
more info
