April 10, 20197 yr Hey guys A google did not bring up much, but was wondering if one needs to do any maintenance on the heat pipes of a solar geyser at all? I have an Apollo system installed with the bare tubes visible and not in a panel, if that makes a difference.
April 10, 20197 yr If they are prone to scale build up you may want to clean up the inside of the tube with acid, but otherwise the cool thing about a vacuum is it contains no dust!
