April 11, 20197 yr IMG_8541.HEIC Hi, After I have been battling to get the infinity to talk to the my laptop and to the Pi and getting that sorted I thought that this afternoon would be a good one to play and see if I can get the setup to work together. I set the inverter to Grid tie backup 3. I got the batteries started and they are picked up by the Pi and the inverter. it seems like the inverter doesn't like the setting of the battery giving warning 13 and 14, easily solved and not really worried about them. The one Im concerned about is the moment I switch the output from grid to solar I get a warning 07- Island Operation detected? Any advice ? is it an inverter setting that I got wrong or something with the setup itself ? Thanks Joggie
May 1, 20197 yr Please describe your objective of the Hybrid Power System and your equipment and then we can advise re: appropriate settings. I'm not sure what you mean when you say "switch the output from grid to solar"
