DEYE Inverter
What should the different settings be on the DEYE 8Kw inverter if I have 3 5.12kW Dyness batteries in parallel (100Ah) each.
There are 3 page batteries settings
Edited by The Eagle
Read the recommended values of the battery and multiply A and Ah by three to account for the three batteries in parallel. Voltages should be set as per battery spec.
Does the battery support communication with Deye inverters? That should manage charging within the limits you set.
