How to Eliminate unwanted Grid Import
Here are the steps and settings worth checking:
Step 1: Disable Battery Saving Mode
Go to:
Battery Settings → Battery Saving → OFF
  • When this is ON, the inverter intentionally draws a small amount of power from the grid to power inverter circuits
  • This is often the main hidden source of continuous import.
Step 2: Adjust Export Settings (If Import Persists)
If Battery Saving is already OFF and you still see ~75W import:
go to:
Storage Mode →
  • Allow Export: Enable
  • Max Export Power: 100
  • Export Calibration: -100
These settings help “push” the system slightly toward export, effectively eliminating small residual imports caused by measurement offsets or inverter control tolerance.
