April 27Apr 27 Item:Rizzen 300 watt Power station 80 amp hour LI-ion batteryAge:3 yearsPrice:R1500Payment Method Accepted:cashWarranty:noPackaging:original packagingCondition:mint like newLocation:Sandringham JHBReason:never needed it . have trolley inverter and 7.5kva genniShipping:noCollection:yesLink:https://www.game.co.za/DIY/Electrical/Generators-Inverters/p/000000000000833524?srsltid=AfmBOoojLZwHxKoKhgItpkcwwW6BMRKctDN3bVdopyMxAVdgoE-hAxHX Edited April 28Apr 28 by icantchooseone
April 27Apr 27 34 minutes ago, icantchooseone said:Item:Rizzen 300 watt Power station 80 amp hour LI-ion batteryAge:3 yearsPrice:R1500Payment Method Accepted:cashWarranty:noPackaging:original packagingCondition:mint like newLocation:Sandringham JHBReason:never needed it . have trolley inverter and 7.5kva genniShipping:noCollection:yesLink:https://www.game.co.za/DIY/Electrical/Generators-Inverters/p/000000000000833524?srsltid=AfmBOoojLZwHxKoKhgItpkcwwW6BMRKctDN3bVdopyMxAVdgoE-hAxHXDoes the manual indicate the Wh value for the battery. Please supply the max size of solar input/Amps for 12V charging/230V AC charge value. The specs on the link is very basic.
April 28Apr 28 Author @Scorp007hi 296Wh ( link below ) . Please supply the max size of solar input/Amps : the only info on the box says this : solar charging : 12.6 ~ 18v . 50W ~ 150W RizzenRizzen 300W, 296Wh Portable Premium PowerStation - RizzenRizzen 300W Powerstation is the ultimate portable power solution. features Solar panel compatibility circuit protection, 80 000 mAh battery life and many more.
