April 16, 20197 yr Hi guys. I’ve searched hi and low. Im looking for an installer that will fit and wire up a system for me. I want to get the parts and I have a fair idea of what I want. Is there anyone that anyone knows in the honeydew sundowner area that does installations?
May 10, 20197 yr Hi All I have an existing solar system, feeding my home and outbuilding. This system is working but does not last the night. I have 6 pylontech batteries but generally I switch back to the grid at about 9pm or so. I will remain on the grid till about 9am or so at which point there is enough solar or batteries charged and system will switch to solar again. Generally, my usage is about 50Kw per day and my solar system produces around 30Kw of the 50Kw required per day. I have 2 DB boards in my home. I would like to isolate the 2nd DB which currently feeds off the 1st DB and I would like to buy solar panels and use the Axpert inverter and batteries (Dynasty UPS12-615MRXF) I already own to power the 2nd DB. Batteries have been standing for about a year now. Can someone please be recommended? I am near the Fourways area. Regards
May 10, 20197 yr 2 hours ago, Gunners said: 50Kw per day I assume you mean 50kWh. I would say that's your problem. You have 12kwh storage and you use 4 times as much 🙂
