13 hours ago13 hr At what intervals should you equalize the batteries? Lithium batteries in particular, I have mine set at 30 day intervals.
6 hours ago6 hr 6 hours ago, Elro said:At what intervals should you equalize the batteries?Lithium batteries have cells balanced by the BMS. If charge settings are according to the battery requirement, leave equalization.
3 hours ago3 hr 10 hours ago, Elro said:At what intervals should you equalize the batteries? Lithium batteries in particular, I have mine set at 30 day intervals.Do not equalize unless maximum cell difference is higher than 50mV or experiencing unexpected shutdowns above the SOC cut-off limit. If you connect BMS to the inverter with data cable and change battery type to Lithium, all battery related settings should be updated automatically and BMS takes control over the charging.
2 hours ago2 hr Author Ok thanks, will change to never, as my batteries have BMS connected with data cable
