June 23Jun 23 Hey guys have a weird problem now not sure why its doing it.got a Luxpower 12Kw inverter with 24 Pannels connected to it and this 15kw batter it's almost a year old now. now the problem is it will randomly just fault out requiring a bms cycle. at first i thought it was perhaps the protocol it was on pylontek so changed it to lux and still does the same was hoping that will fix it.what i did now is change the can cable from cat 5 to cat 7 to see if that's what's causing it it has a pace 16s 200A BMS with the pace tools I cannot see what the problem is. cell balancing is is about 5 - 20 mv apart depending on how high the load isgenerally, it's under 10mv 90% of the time anyone experienced this problem before
