Sunday at 02:245 days I have 4 x 24v 200AH batteries connected to a bus bar, the spec of the batteries are 100A max continuous charge each, will the 100A be diluted by 4 from the inverter or does that not matter as the amperage will stay the same to each battery no matter how many batteries are connected to the bus bar?
Sunday at 02:395 days 14 minutes ago, Elro said:100A be dilutedProbably your batteries are connected in parallel and yes, then the charge current of the inverter will be split in four.
Sunday at 02:445 days Author Yes they are connected in parallel, so I should be able to run the inverter at maximum of 180A
Sunday at 04:165 days 1 hour ago, Elro said:I have 4 x 24v 200AH batteries connectedConnected in parallel, this will give you 96v - what inverter are you connecting this to???
Sunday at 05:385 days Author Its a conderenergy 5kw 24v with 50mm core cables from batteries to 350a bus bar then 90mm core cable from bus bar to 250a disconnect fuse box then into the inverter
Sunday at 05:445 days Author Demo, in answer that wont give you 96v in parallel, in series yes, the volts will stay the same in parallel
Sunday at 05:585 days 12 minutes ago, Elro said:Demo, in answer that wont give you 96v in parallel, in series yes, the volts will stay the same in parallelTrue, was thinking abut series connection 😊
