July 2, 20197 yr Hi I have installed a Goodwe 4.6 es grid tied system including 4 x Pylon us2000b batteries. I want to add 1 or 2 more batteries but if you look at the PV master app ( basic setup) it only indicates Pylon us2000B *1 Pylon us2000B *2 Pylon us2000B *3 Pylon us2000B *4 Does these setting matter if I add more batteries to by stack? thanks andre
July 2, 20197 yr Hi I just added us3000 (x2) onto a goodweEM unit, had to do a firmware upgrade and select the us2000*2 option.Without the update the inverter goes into fault and drops all power. Under correction i think you can have 6 us2000 stacked then any more and a coms hub is required. So in short yes check the correct config and get the required files first
