September 4, 20197 yr Victron have just released their first version of "Wiring Unlimited" - see https://www.victronenergy.com/blog/2019/09/03/wiring-unlimited/ Although produced by Victron, this book covers a wide range of topics that apply to any installation, irrespective of the brand of equipment. Topics covered are as follows: Ohm’s Law Power Conductivity and resistance Current, cable resistance and voltage drop Negative effects of cable voltage drop Ripple Battery bank wiring Battery bank Large battery banks Parallel battery bank wiring Battery bank balancing Battery bank midpoint DC wiring Select the right cable Busbars Cable connections Fuses and circuit breakers DC isolation switches Shunt Parallel and/or 3 phase system DC wiring Large system busbars Voltage sensing and compensation Solar panels Communication wiring Data signals Interference Communication cables and connector types Interfaces AC wiring Power generation Distribution networks System current VA and Watt AC wiring Fuses and circuit breakers AC bypass switch Special considerations for AC wiring of parallel and/or 3 phase inverter/chargers Ground, earth and electrical safety Electrical safety Earth wiring RCD Neutral to earth link in inverters and in inverter/chargers Mobile installations Isolation and grounding of Victron Equipment System grounding Galvanic corrosion Preventing galvanic corrosion The galvanic isolator The isolation transformer Enjoy!
September 4, 20197 yr 2 minutes ago, NigelL said: Wiring Unlimited It's absolutely excellent. Margreet did a very good job. It also deals with a support issue that has caused me lots of frustration in the past: Parallel systems that feed into the grid or draw from it proportionally to the load. When you see that.. it is almost ALWAYS a cabling issue. And this book explains it so well.
September 4, 20197 yr Freaking nice @NigelL for spotting it! And there we go with it .... https://powerforum.co.za/files/file/44-wiring-unlimited-a-must-read-for-all-newbies-and-old-knees/ Edited September 4, 20197 yr by Guest
September 4, 20197 yr Check out the MPPT Solar Calculator ... https://www.victronenergy.com.au/solar-charge-controllers Here ...
