November 19, 20196 yr Hi all, I use the QPIGS command from Python to monitor my Mecer (Axpert) 3kVA 24V inverter from a Raspberry Pi. Currently I leave it in SENS mode in the settings so that it only fully turns on the inverter when a load is detected. If the load is over about 100W then this works fine and it turns on, however anything less than this and it won't turn on. Is there a way to turn it on for lighter loads without going through the settings using the buttons on the front and switching it to SDS (I think that's the other value)? I was hoping maybe I could use a command in Python from the Raspberry Pi and then trigger the script from my phone. Thanks.
