Upgradeable Solar Package
Hi to members and readers
I am looking to start a phased approach to a Hybrid solar solution - would like advice on an Axpert King vs Goodwe/Victron Inverter together with advice on batteries as an initial backup system to be upgraded to a 5kwH solar system over time (can add batteries and panels at a later stage)
Would like advise from members that may have done this in the past as well as the experts out there
Welcome moemoola
If i understand you correctly, you want to install an inverter and some batteries as a "UPS" system with the hope to upgrade to a solar system later.
In this case, buy the 5kw unit now, or go for a 3000VA Victron and add a another later when you are ready to upgrade.
43 minutes ago, moemoolla said:
advice on batteries
If you plan to upgrade over time, you will need to look at Lithiums. If you choose Lead Acid batteries, you only have a 6 months window in which you can add more. With lithiums you can even add another after 2 years if you want to.
 Before you decide, you will need to give us a better idea of the loads you like to run during a power outage.
Thanks Jaco
Looking to keep some lights in the house and TV, decoder and a few plugs with no large appliances or the like going in the downtime.
Main thing is the scalability - average monthly use in the house is 800kWh
That you will get with Victron. Adding on is always possible . You can add another inverter giving you 6 kva, and when you are ready you can add the GX and some MPPT's as well as Panels.
