Schubart 3KW 48V LiFe + Axpert
Anyone using this battery, what is your bulk charging (54V?) and floating voltage settings?
Sorry if its has been asked before. I'm new to this, trying to figure it out ;-)
  • 1 year later...
Does anybody in South Africa know, what the settings on a Victron BMV should be for this battery? Nobody so far can tell me what the settings should be. It connect to a Raspberry Pi ICC via USB , and also the Inveter Via USB to the Pi.
My setup:
1 x Mecer Apert 5kW inverter
2 x Schubart 48V 3Kw LiFe batteries connect in parallel
12 x 360w SolarPanels - 6 per string in series - 2 strings g to Combiner box and then to Inverter
Thanks in advance.
