February 23, 20206 yr What is the settings on a Axpert Inverter and a Growatt Inverter if you use 4.8 Kw & 2.4 Lithium-Icon Batteries. Eskom is kicking in to Fast. I had no problems in the past with Gel Battries.
February 24, 20206 yr 16 hours ago, Cornelius said: What is the settings on a Axpert Inverter and a Growatt Inverter if you use 4.8 Kw & 2.4 Lithium-Icon Batteries. Eskom is kicking in to Fast. I can't say for Growatt inverters (do you have both?), but these are the figures I'm recommending for PylonTech batteries (the same could be used for other 15S LFP batteries; you didn't say what brand or model or chemistry your battery is). I note that I've tuned some of the recommended settings compared to the first iteration of this image (e.g. for setting/program 29) following data from other posters (thanks to those posters).
