April 9, 20206 yr Good day, I have a 5 core cabtyre cable (flexable lead with 5 insulated cores inside) with 380volt rating. Can I use one core for earth, two cores for dc12v to power LED's and the other two cores to run a 220V AC fridge? The length of the cable is about 2 meters.
April 9, 20206 yr 1 hour ago, Redge said: The length of the cable is about 2 meters. With that short length you will be fine. With long lengths there is significant inductive coupling between the high voltage AC to the low voltage cables.
