May 16, 20206 yr I recently bought a secondhand 3kw/24v MKS Plus from a member here. It worked ok for a while, albeit with the Fault light flashing (01 - Fan issue) which was a known issue and had been there since the fan has been replaced. Now the Fault light is on permanently and only the DC charger is working, it's not inverting. It still shows 01 error but I'm not sure if there are other errors too? Is there a way to check this in the ICC Pi? When the inverter first starts up both fans spin a little bit and then dies down.. This is what the logs say:
