Karel SABS
Morning
I have installed a 4.6kwh goodwe 5048d es for a client  .
The inverter at times.
What is the correct capacity setting and charge voltage .especially when the sun starts to rise and strangle sometimes at night around 10 .
No overloads . Load normal very low. what is the correct battery capaicty setting and charge voltages.
It uses 2 x 2,4 kwh lithuim ion batteries
Morning
Morning
The inverter at times just trip especially at sun rice
What is the correct capacity setting and charge voltage .especially when the sun starts to rise and strange  sometimes at night around 10 .it just trips and switch on again after a few minutes . Goes well again for a day or two then starts tripping  again
No overloads . Load normal very low. what is the correct battery capacity setting and charge voltages. People said it could be settings
