May 5, 201610 yr How often does the bulk process happen on the Axpert inveter ? And for how long? What battery fuses are the best to be use on a 24 volt system, or circuit breaker
May 5, 201610 yr Manie there is a cart in the manual that shows you the process. It happens every day if your batteries are used.
May 5, 201610 yr Thanks Jaco. If i look at my battery volts for the past 3 days, it does not look if its going to bulk stage Sent from my SM-G920F using Tapatalk
May 5, 201610 yr For how long must it stay at that voltage before going to float? Sent from my SM-G920F using Tapatalk
May 5, 201610 yr From bulk it should first go to absorb stage then float. Nice explanation here (no real set time depends on how full/empty your battery is) https://www.batterystuff.com/blog/3-stages-of-smart-chargers.html
May 5, 201610 yr Yes i undertand you bulk absorb etc. Work. I want to know if the users with a Axpert inverters see when it is on bulking stage. I dont know if Jaco software locks the battery volt over 24 hours or 3 days. You should see it on a chart when the voltage go to bulk stage. Sent from my SM-G920F using Tapatalk
May 5, 201610 yr His software does not log it but if you setup Emoncms you can do it. This is mine from yesterday
May 5, 201610 yr Thanks viper. Thats what i wanted to know. Looks like about 3 hours on yours. Now i wonder why mine does not show. Can it because i only discharge about to 98%.? Sent from my SM-G920F using Tapatalk
May 5, 201610 yr Yeah mine was from about 80% SOC 98%(looks like inverters self consumption) is definitely why you are not seeing it as it's not needed, do you turn off everything at night
May 5, 201610 yr Lol Thanks Viper , i will discharge the batteries to about 80% and see if it does go in to bulk stage. The last few days the inverter was bypass at night
May 5, 201610 yr The software does log it to the database, I just does not graph volts or SOC on the AICC side. I still wanted to add that to the Battery Tab. But I do send the values to EmonCMS as Thys showed above. I just draw watts on the AICC side.
