September 3, 20206 yr The manual states that these units cannot operate in Parallel the question i have is can they operate in Series The First unit running a stove and swimming pool ( Gas Geysers ) and the other unit running the rest of the house
September 3, 20206 yr Got the specs for this site>? Is this the right inverter?https://voltronicpower.com/en-US/Product/Detail/InfiniSolar-E-5.5KW AC input is 40 amps AC output of the inverter? 23.9Amps Think your first inverter is going to work very hard or not at all with the pool and stove. Edited September 3, 20206 yr by Barryv add the link
September 3, 20206 yr Author 10 minutes ago, Barryv said: Hello what is the KVA of the first inverter? 10 minutes ago, Barryv said: Both Inverters are the same the Rating max is 6.3KVA on each unit
September 3, 20206 yr Author The First Inverter has two pv strings the pool to run from 9 untill 11. The Stove is to be used between 11:15 and 2:15 the only load from the second inverter is 200W The Second inverter also has two strings and runs the rest of the house just fine. No extrapower needed from the first inverter. The Evening load is never more than 1.3Kw will come from the 1st inverters batteries neither of the inverters will feed back into the grid . I am thinking about earth being common in the DBs that could cause a problem
September 3, 20206 yr Ok. Just make sure the settings is correct otherwise you will blow your first inverter. You don’t want you second to feed back to the first inverter. Let’s see what the Professionals have to say. This is risky to connect a inverter onto a inverter.
September 8, 20205 yr Author I guess with no comment from the experts this makes you the expert thank you Barry your replies are appreciated
January 30, 20215 yr Author After many months of getting the manufactures to understand the question the answers is yes the second inverter needs to be set to offgird. ( Which is actually Grid Tie with Backup and no feedback to the Grid )
