January 18, 20215 yr Hi all, I have a 5000VA Multiplus II and I just installed 4 x Pylontech US3000B batteries. I connected all as per Pylontech/Victron manual I additionally bought original VE.Can to CAN-bus BMS type B cable to connect the master battery to Venus GX in order to get the BMS info, but no luck. Some pics of the connections attached I have changed Victron Config as well as ESS settings as per Victron manuals Can anyone help? Any suggestions are welcome. I really don't know what am I doing wrong? (I tried the fourth jumper up and down - no luck) Edited January 18, 20215 yr by Bobby Kaucic
January 19, 20215 yr Author All sorted! Thank you My replies are hidden for some reason when I thank the people that helped 🙄 the problem was the 500Kbit/s on Can-bus. Once it was set, it started working
