February 12, 20215 yr I moved into a house that had a "UPS" system installed. It is Synapse 5.0K+ Inverter with 4x Champion 6FM200G (12V200ah) Lead Acid Gel Battery(Dated 20190425). Lately with load-shedding the whole system shuts down in less than a hour with a constant load of +- 300-400VA. Now I have 2 questions. 1. I assume a battery, or multiple batteries are faulty. How would one go about testing these batteries. 2. What are all the charging settings on the inverter suppose to be for these batteries. I have no idea who installed this system or if it is even done correctly, hence my wanting to verify what should be the correct settings on the inverter for these batteries.
