March 15, 20215 yr From normal use calculated from monthly use, a 5kW inverter is sufficient. But since I have 3 old school fridge/freezers, I am afraid that peak power use might be more. I need to measure possible peak usage. Is it possible to hire a meter somewhere, or how is this usually done?
March 16, 20215 yr 6 hours ago, Brani said: Effergy meter will record your peak power. But I found it limiting as it just showed me the highest peak ever. If you monitor it regularly, you can get a very good idea of what your highs are. I think this is where the efergy hub beats out the classic as you have real time online analysis.
March 19, 20215 yr Author Thank you, I enjoyed the read..haha I decided to go for the 8kW Sunsync instead of the 5, just to give me room for upgrade. Future might install fencing and pool heatpump.
