Axpert Max 8kW Inverter...
Greetings Braintrust - I'd be curious to hear your comments on the Axpert Max (8kW version) - from a build perspective - to the smaller units, It is  cut above the 3kVA and 5kVA units and seems to be a professional and neat solution.
It is the first time that I've seen the Watchpower app in operation via the built-in Wifi module - does anyone know if the app can send out alerts/notifications  (for example when utility AC fails and the unit operates on batteries - as well as any other alarm/functional issues).
Any other comments (positive/negative) on the unit would be greatly valued!
Vaughan
  • 5 months later...
