May 7, 20215 yr hi output of 5kw inverter between neutral and earth voltage detected input from the grid side ok where can i look for the fault trips the earth leakage on the input from the grid everything run normal otherwize
May 9, 20215 yr On 2021/05/07 at 10:34 AM, jean coljee said: output of 5kw inverter between neutral and earth voltage detected What model inverter? If an Axpert type, how old is it? My understanding is that the later Axpert / Mecer / RCT / Kodak etc models all have a relay contact that should fix this.
