September 1, 20215 yr Centurion Solar just installed their new software, SMH thank you! It's a bit of an upgrade from ICC and they even set it up on my Home Assistant! After Hours no less. The dashboards has been reworked and looks beautiful. Thank you guys from Centurion Solar great service as usual. Also if you are still on ICC drop them an email and ask about SMH you will not be dissapointed.
September 1, 20215 yr I still have ICC. But I don't use it for anything more than a bridge between Home Assistant and the Inverter. I use my own dashboards and NotRed for automations that control the inverter over MQTT.
July 13, 20224 yr HAs anyone installed the new SMH 3.0.0. firmware update for the PI, if yes please advise where or what I have to do to load the software to my Pi. My phone will no longer work with the ver2.1.0 firmware installed.
July 14, 20224 yr 18 hours ago, Venom said: HAs anyone installed the new SMH 3.0.0. firmware update for the PI, if yes please advise where or what I have to do to load the software to my Pi. My phone will no longer work with the ver2.1.0 firmware installed. @Venomlog into your pi. Login on the SMH desktop app. Then navigate to the settings page/tab. You will see an upgrade button in the lower left area. Just click on it and let the process run. If you still dont manage to upgrade just give the office a call and they will help you.
