September 26, 20214 yr Hi all, So I've got a King 5K (5kw) inverter which has been updated to the latest factory firmware. But I've noticed that the inverter doesn't want to switch from Solar/Utility/Battery back to Solar/Battery/Utility. The only way is the disconnect the mains supply to the inverter instead. Not sure if I am missing anything? Battery bank. Pylontech with the inverter connect with the BMS
