September 27, 20214 yr Hi I would like to ask if the Ethernet Cable is straight or cross. I need to change VM III LCD location. Also Connect VM III to Raspberry Pi. I am new to this forum and inverter. TY
September 27, 20214 yr 4 hours ago, 3liswaid said: I would like to ask if the Ethernet Cable is straight or cross. It's straight through for the Axpert King, and the VM III uses the same removable display, even with the same display firmware. So it's straight. Any ordinary LAN cable would do.
September 27, 20214 yr Author 10 hours ago, Coulomb said: It's straight through for the Axpert King, and the VM III uses the same removable display, even with the same display firmware. So it's straight. Any ordinary LAN cable would do. thanks for the answer
