Wanted Mecer SOL-I-AX5P or equivalent RCT
Item Wanted: Mecer SOL-I-AX-5p or equivalent RCT
Packaging Essential: No
Desired Age: 3 years or less
Willing to accept a shipped item: Prefer to pick up within reasonable distance (<500km)
Ballpark/Budget Amount: R10k
Must have a parallel kit. Am willing to take two.
These are the 5kW/5kVA units (i.e PF1.0) with an 80A MPPT with max open circuit voltage of 145V.
Will also consider the equivalent Axpert King (will need to be two though).
Hi Dewald,
Thanks for the reply. I'm a little concerned that these may be clone inverters as I need to run on @Coulomb and @weber firmware and the chances are good that it will brick the unit if I try to flash it and it is a clone. Looking at the label I would say it almost looks like a Voltronic but reading on the AEVA forum it seems these may be clones. Where did you get these?
