November 30, 20214 yr I have installed a Mecer 8Kva inverter installed at my premises. I am not sure if the installer has set the parameters correctly as i get intermittent power cutoff for a few seconds and restart. Can you help me with the parameter settings procedure.
November 30, 20214 yr 2 hours ago, Ricky9 said: i get intermittent power cutoff for a few seconds and restart. Can you help me with the parameter settings procedure. Settings depend on many factors: what sort of battery you have, how it is connected, what your preferences are (e.g. prefer longer run time during blackouts, or prefer to minimise utility energy usage), etc. Certainly power cut-off and restart sounds bad. I think you should contact your installer in the first instance, or give us a lot more details about your system.
