December 21, 20214 yr Hi, hope you all are well. Semi new to solar and need to upgrade as I would like to go off grid. Could someone give me some clarity on my situation please. I would like to parallel 3x spf5000es inverters per phase(all our farm wiring is 3 phase). So hypothetically total of 9 inverters. What is the max Amp output per inverter and does the amp multiply by 3 per phase if 3 inverters are connected in parallel per phase. My biggest motor is 15kw rated at 31A. Would the inverters be able to start it up and run smoothly without utility(eskom). I currently have have 4x pylontech us3000c batteries, should I add to them or replace with Revov first life. Kind regards. Chris Jensen.
December 22, 20214 yr In theory yes they should work. Since I have no practical experience the only thing I can add is that your battery bank will also grow by a lot. For example recommended battery size for 3 inverters is 600amphours.
