January 23, 20224 yr Morning All, Would just like to confirm DIP switch settings for using 2 x LBSA 51.2V 105Ah LiFePO4 batteries in parallel. According to the spec sheet as bellow it should be as follows: Master 1 2 3 and 4 = Off, 5 = On, 6 7 & 8 = Off Slave 1 = On, 2 3 4 5 6 7 & 8 = Off Thanks MdF Edited January 23, 20224 yr by MdF
January 23, 20224 yr Phone the OEM I think they will be in a better position to advise you. The number is on the manual.
January 24, 20224 yr Author 20 hours ago, MdF said: Or represented graphically: Have confirmed with LBSA this morning via email that the DIP switch settings as shown here are correct for this setup. I have made the changes, rebooted the system and SA. All seems working fine but will monitor and advise here of any changes or problems. MdF
