February 7, 20224 yr Hi all. I'm running two Axpert King inverters in parallel with a single 100ah Narada lithium battery. Have been using Solar Assistant to monitor the setup, including SOC from the Narada. I have recently experienced my battery being fully charged and instantly dropping to 0% SOC. This is confirmed by the indicator lights on the front of the Narada so it's not a reporting issue in Solar Assistant, I don't think. Is my battery dead? Any thoughts would be appreciated.
February 8, 20224 yr Author This morning I turned the battery back on to show how with just the smallest charge input (solar input at 7.05am) and the battery will in a very short space of time report 100% SOC.
November 8, 20223 yr Good morning Miles, I have a similar issue but my Narada but the SOC is always at 99% How did you connect Solar Assistant to use the battery? I eventually used the "USB Serial RS232/485" with the cable from Solar Assistant but the reading are way way off - so using the "emulated bms" on Solar Assistant.
November 14, 20223 yr Thanks - unfortunately mine doesn't work... hope you can find a solution to your problem as well
