February 15, 20224 yr Synsynk 5kw inverter is switching the non essential circuits on and off all the time, sometimes the power to the essential circuit is off but mostly the inverter keeps switching the grid signal for relay on and off, and then the screen shows 0kw input from grid but the non essential circuits run fine no power cut to them. I did have a lightning strike 3 days ago and then this started
February 15, 20224 yr 1 hour ago, Japie60 said: Synsynk 5kw inverter is switching the non essential circuits on and off all the time, sometimes the power to the essential circuit is off but mostly the inverter keeps switching the grid signal for relay on and off, and then the screen shows 0kw input from grid but the non essential circuits run fine no power cut to them. I did have a lightning strike 3 days ago and then this started Hi Japie. Best would be to contact your insurance company so they can send out someone to do an assessment and lodge a claim. Regards
February 15, 20224 yr Author Found the problem floating neutral, causing voltage to drop to 180v from council then inverter turns on, couple of minutes later the voltage goes to 205v inverter switches off But tks
