February 22, 20224 yr Gentlepeople Can someone help me to double check if my battery settings are correct. Float etc. I have 3x 48NaradaNPFC100A batteries. They don't talk to the Sunsyk8 Inverter, so we had to set them up as AGM Setup Sunsynk 8kw 3 x Narada Batteries 12 x Poly Canadian Solar 405 watts, 2 strings on one MPPT (MPPT1) Help will be appreciated.
March 2, 20224 yr On 2022/02/22 at 10:35 AM, Sadeck said: Gentlepeople Can someone help me to double check if my battery settings are correct. Float etc. I have 3x 48NaradaNPFC100A batteries. They don't talk to the Sunsyk8 Inverter, so we had to set them up as AGM Setup Sunsynk 8kw 3 x Narada Batteries 12 x Poly Canadian Solar 405 watts, 2 strings on one MPPT (MPPT1) Help will be appreciated. So what are your battery settings ?
March 2, 20224 yr I had the same issue with the 150ah narada batteries. Your values seem too high. Was told the safer settings are. Float 52.5 Absorbtion 53 Equilization 53. They are working on a firmware update.
March 3, 20224 yr Author Thank you ; Will set accordingly. Don't know when Narada is going to fix the BMS COMS issue.
