Sunsynk 8kw Soc 0%
On 2022/03/03 at 8:26 PM, Farotek said:
8kw Sunsynk:  Why is Soc dropping to 0% and the system shuts down . When you switch inverter off then on it starts charging.
i had this also on my deye 5kw will be 100% then drop to 0%
this is a communication issue with the bms i had on a shoto battery . once we changed the bms on the shoto battery everything is perfect  again
