Sacolar M5000H-48BP
Hey all
So we just got 2 x Sacolar M5000H-48BP inverters because our previous Axpert clones popped their MOSFET's for the 3rd time. Not over heating or anything.
For those that dont know, Sacolar is made by Growatt and from the spec's it appears that they are the exact same as the Growatt SPF5000ES inverters.
The interface, specs, etc are identical, casing is different.
Nevertheless, I am hoping that the growatt users can assist.
On the Axperts under setting 19, you were able to set it that the screen remained on the last screen you viewed, rather than it changing back to the voltages screen after 1 minute.
Is this setting possible on the Growatts? I've been through the user manual and googled for a good portion today, I cant find anything.
2 hours ago, Buyeye said:
Hi sorry 19 is bulk voltage on the growatt.
Sure, I get that. What I was saying on the Axpert Clones it was under setting 19. What setting would it be on the growatts?
  • 10 months later...
I would also like to know this. My display also jumps back to default on Sacolar. Are you happy with the Sacolar so far?
Unfortunately no setting to change it.
Yes, it has been amazing especially when paired with Solar Assistant
19 minutes ago, Frans Ackermann said:
Will this Inverter be compatible with a UP5000 Pylontech Battery?
From what I can gather, yes.
Same settings as a Growatt SPF5000ES
  • 7 months later...
