Victron BMV smart shunt settings
I have a DIY battery with a ant bms. I added a victron BMV monitor with a (ve.direct cable) to get SOC for ICCsoftware with a axpert inverter).
Problem i am having is that the bmv over time looses the correct state of charge (compared to the BMS which appears to be more correct)
Overtime the BMV shows a lower SOC compared to what the battery actually is. (when cells get to around 3.4 they should be showing near 100% SOC on the BMV)
Not sure if anyone know the correct settings on the BMV.. there was a long list, i guessed most of settings so not sure what others have used.
I charge the battery to 54.4v which should be close to 100% SOC right..?
Still need to spend time fine turning the BMV, thought I could start here:)
Many Thanks,
Ian
Edited by IanLaing
Mmm, i don't think so.. Must be a the shunt setting I need to change.. Maybe my voltage on the shunt is set to high and so when reaching full charge (based on voltage) its not "resetting" back to 100%....
Guessing at this point..
Will have a look at the shunt setting in due course.. Hoping other have set these shunts up if there is something I can look out for..
Could not find the settings for a 16s battery..
Good Luck with your build! building DIY LI Ion batteries is not for the faint hearted!
Edited by IanLaing
