Multiple charge controllers
I have a quick question
I have an Axpert with lithium batteries. The inverter can charge at max 25A from AC but I could charge with a much higher amp on the lithiums
Am I able to connect an additional AC charge controller to the batteries such as this:
https://www.livestainable.co.za/product/victron-energy-blue-smart-ip22-24-81-230v-cee-7-7-battery-charger/?gclid=Cj0KCQjw_4-SBhCgARIsAAlegrXiFk9jAB-HRs13msKP6Do_cIm3gMDZ6GiRLmeLNkWgkm0CywIXrYoaAp99EALw_wcB
AFAIK there should be no problem connecting this charger to increase the charge rate from 25 to 33A. You are fortunate that you get this charge rate from the Axpert. Mine refuses to go even to 20A charging lithium even if I set it to 30A.i expect some bug.:(
