I need 5kw 48v control board
There are many subtly slightly different versions of these, be very careful to get the right one. It would be best to get it from Voltronic via your supplier, since it should have the bootloader, and some clone manufacturers haven't copied that part of the firmware yet. Without the bootloader, you can't update firmware, and may run into troubles with fault code 90 months after installation.
