June 24, 20233 yr 21 minutes ago, Flouw said: What is your output priority. And charge priority set to? Im not sure what you have set to max. You will have to list all settings. 1. Uti 2. 30a 3. Ups 4. Sds 5. Use 6. Ltd 7. Ttd 8. 230 9. 50hz 10. 2 11. 30a 12. 25.5v 13. 26.8v 14. Snu 15. Bon 16. Lon 17. Aon 18. Byd 19. 28v 20. 27v 21. 22v 22. Sbe 28. 1 43. Dl5 44. 29.2v 45. 60 46. 120 47. 3 48. Tof
June 24, 20233 yr 26 minutes ago, Flouw said: What is your output priority. And charge priority set to? Im not sure what you have set to max. You will have to list all settings. It should only use battery when there is no power incoming. Otherwise what is the point of having the system if it keeps discharging every 2 or 3 days. It means battery gona run out way sooner than intended. And all i read on forums is basically the growatt doing this.
