Li Iin batterys without BMS
Hi . I seem to have an issue on my small 12v setup. The system went dead on me and when checking the bms only shows 0.3v ouput on . If I measure across the cells I get over 13v. I have 8 li ion cells 200a on a daly 12v 120a 4s bms. I want to know if i could temporarily bypass the bms and connect my batteries directly to the 12v inverter.
18 hours ago, Scorp007 said:
Yes you would. Just ensure that you don't discharge to lower than 12V and when you charge to over 14V.Then get a BMS soon.
Thanks. On it first thing Monday
